Feature Request: Folders or Collections in the Documents View
Emberton Electrical
Aug 10, 2026
10
5
I like the recent change combining Reports and Pages into the Documents area, and I also appreciate that Documents are searchable and can be filtered.
I would love to see an additional organizational layer added: folders, collections, or some similar way of grouping documents within a project.
As CompanyCam becomes a more complete project record, the Documents area can quickly contain very different types of information:
  • Daily Reports
  • Weekly Reports
  • Permits & Inspections
  • Site Plans
  • Drawings
  • Specifications
  • Project Notes
  • Client Documents
  • Other project-specific records
Search and filters are useful, particularly from an administrative perspective, but they don't completely replace simple visual organization.
My biggest concern is quick field access.
If one of my crew members needs the site plan, permit or latest drawing while standing on a job, I want them to be able to open the project, go to Documents → Drawings and immediately find it.
If finding a document requires searching, remembering its name, selecting the correct filter, or scrolling through a mixture of daily reports, notes, permits and drawings, field adoption becomes much more difficult.
A simple folder structure could make the Documents area much more useful as the project's working reference library.
For example:
Documents
  • Daily Reports
  • Weekly Reports
  • Plans & Drawings
  • Specifications
  • Project Notes
I don't think this needs to replace the existing search and filtering tools — I think the two approaches complement each other.
Search and filters are excellent for finding something. Folders are excellent for knowing where something is.
For office use, either method works. In the field, reducing the number of taps and decisions required to reach an important document can make the difference between the crew actually using the project documentation and simply calling or texting someone to ask where it is.
As more project information moves into CompanyCam, having a simple organizational structure within Documents would help make it practical as both the project record and the crew's everyday field reference.
  • Daily Reports
  • Weekly Reports
  • Site Plans
  • Drawings
  • Specifications
  • Project Notes
  • Client Documents
For example:
Documents
  • Daily Reports
  • Weekly Reports
  • Plans & Drawings
  • Specifications
  • Project Notes
Hey there!
Loving all of the feedback and feature requests today. Keep 'em coming!
We built Folders alongside the Documents tab for exactly the reason you're describing. Search is great once you know what you're looking for, but your crew shouldn't have to think that hard to pull up a drawing.
You can build out the structure you laid out above. Click +Create > New Folder to create Daily Reports, Permits & Inspections, Plans & Drawings, and so on. Then click the three-dot menu to the right of any Document and select Move to Folder.
Here's a step-by-step walkthrough: https://help.companycam.com/en/articles/16130532-organizing-documents-with-folders
Give it a shot and let me know if the structure holds up in the field. Genuinely curious how your crews take to it.
Thanks Shayla — that was a very quick and helpful response. I gave the folders a try and they work exactly as I was hoping. It’s clean, intuitive, and makes the Documents area much more useful for field access.
The only improvement I noticed while setting it up is that documents currently need to be moved into folders one at a time. Since CompanyCam already has bulk select/edit, tagging, and moving for photos, it would be great to see that same functionality carried over to Documents — particularly bulk Move to Folder and tags.
Tags could also make document search and filtering even more useful alongside the folder structure.
Other than that, the folder implementation is super clean and efficient. Thanks again for pointing me in the right direction and for being so responsive to the feedback today!
  • Love
Reactions: Shayla C.
This is great to hear, thanks for circling back and letting me know it worked!
You're right about bulk actions. Setting up folders on a project that already has a pile of Files in it means a lot of clicking. I've passed that along to our product team, along with the tagging idea.
No timeline I can promise you, but this kind of feedback is exactly what shapes where Documents goes next. Keep it coming!
